Reel Pole-tential
- Feb 16, 2003
- 7
Was out about 45 miles from ST AUGISTINE Saturday when something Wierd happend.<br /><br />Engine was running fine all day, until I went to retrive my marker bouy. I overshot and put her in reverse for a second, Took her out of Gear and retrieved the Bouy, went to put her back in Gear and the shifter was real hard to push, so I put her back in Reverse then out of gear and to Forward and she went, a little resistance but ok.<br /><br />Well got going on plane, and backed down to 4500 due to conditions of the sea (bumpy) anyway about 4 miles later the engine starts to bog down like I have a shaft break or Im towing 2 tons of bricks behind me. Well, I stop, lift the engine to see if I picked up anything, and there is nothing there. I put it back in gear and get up to 3400 but she is still laboring to get up (WO is normally 5900) So I put her to wide Open and she gets around 4200 or so. but with every Swell she has to spool back up (few seconds) then she opens up again like she is ok, then hit another swell and she boggs down again. this goes on for a while I knew I was burning gas at a very high rate due to the drag on the engine. Well I end up running out of gas 13.5 miles short land. Sea tow brings me more gas 2.5 hours later, while waiting I keep on cycling the shifter until it losenes up to normal resistance. I get gas put her in gear and she takes off a little less then normal but not bad I put her to W/0 and Im still 800 off my normal operation, I get to the ramp get her on the trailor and she runs out again.<br /><br />(normal fuel burn is approx 1.9 to 2.1 mph but I burned 10 gallons in 14 miles) I belive the exsive burn was due to a fouled plug caused by the over-load on the engine the previouse 35 miles, but Im wondering what could of bogged the engine down that bad? Im thinking its something to do with my Gear Case/Linkage out of adjusment..anyone else every have something like this happen??
