87 sea nymph ignition key switch
Jeffsasin
I just got a 87 sea nymph fish n ski. It has an Evinrude 140hp v4 outboard. I need to know where I can find a ignition key switch with keys
Silvertip
Right here on IBoats. Click on the boat parts and accessories tab at the top of the page. Is the ignition switch on the console or on the shift/throttle control box? Either way, IBoats would have it.
gm280
:welcome: Aboard Jeffsasin to iboats...
You can buy replacement ignition switches everywhere they sell boating supplies. Just make sure the replacement switch has the same functions as yours. If you have a ignition switch with a push to choke feature, then make sure your replacement one does as well. Other then that, you shouldn't have any issues locating one. If fact they sell them here on iboats parts section... :thumb:
Fleetwin
Yes, make sure you get the switch with the "Push to prime" feature. Yes, iboats will have it.
lmuss53
If you just lost the key you can get the number off the little plastic ring in the face of the switch and get a replacement from an Evinrude dealer.
