Greetings,
I have an '87 Black Max 150 HP and have a Sterndrive Engineering lower unit (have used it 5 years with no issues). I recently changed the impeller as routine maintenance, but am concerned about high water pressure at idle and higher RPMs.
At idle on the muffs at 1000 RPM, I'm getting 14 PSI with cooler water coming out of the telltale. I have the "tee" fitting with one line coming down from the 2 t-stats merging into the tee with one line going into the lower block and the other one goes to the telltale. With an IR thermometer check, the block is barely getting to 100 degrees on the muffs and the top of the block is cool to the touch. I did take the t-stats out (new last year) and tested them and they opened and closed as they should.
At higher RPMS, I'm showing about 20 PSI at 4000 RPMs and over 30-35 PSI at 5000 RPMs (I quickly backed off). I do not have a temp gauge or working overheat alarm to my knowledge, so I've always relied on the water pressure gauge. This engine has never run over 15-18 PSI before at WOT.
I checked the poppet valve and it wasn't sticking, dirty, leaking, or clogged with debris. At idle in the driveway, there is water coming out of the prop steadily at idle, but seems possibly less than in the past.
At this point, I assume something is restricting the amount of water exiting the powerhead. Should I pull the powerhead and check for any debris in any of the exhaust outlets?
If so, what gaskets would I need to purchase? Would I also need to pull the heads and check for any debris in there or the block?
Thanks for any thoughts or advice!
