88 125hp Force Have Spark Wont Fire
RealRockers Usa
I Have a 1988 Force 125 Hp Motor i started it warmed it up & It shut off & would not re fire is it possible the fule pump went bad checked my spark have spark on all 4 plugs Am I missing something motor was well maintained or are there some kinda saftey switches on it like for bad impellor or the nuetral safety switch might be bad??? or should i go ahead & take it to the dealer at $145.00to diagnose it. Any Info would be appreciated Dave. vikkiandave@hotmail.com :( :confused:
Down South
Re: 88 125hp Force Have Spark Wont Fire
If you have fire at all cylinders then switches aren't the problem. Squeezing the primer bulb will get fuel to the carbs reguardless of the fuel pump condition. <br />What about your fuel condition? Is it fresh & clean? If you had water in it, it can sure cause a problem.<br />No, don't take it to a dealer just yet. Your problem sounds minor and probably easily fixed.<br /><br />Ok, Did you try and use the primer bulb to make sure it was tight. Did you try the choke?
RealRockers Usa
Yes fuel is fresh had run the motor 4 times without a problem bulb gets tight checked the floats also not stuck What about the impellor if its bad would this be a problem for starting??? All It does is crank acts like its not getting spark but it is any other suggestions?? :confused: also tryied choking motor still nothing
