'88 70 HP Johnson 3 cyc..stalls at idle but...
jholley
The engine stalls at idle when the lift is all the way down.....but if I raise the engine a few inches, it idles perfectly!!!!<br /><br />Anyone have any ideas?<br /><br />Thanks.
rickdb1boat
Re: '88 70 HP Johnson 3 cyc..stalls at idle but...
Remove the carbs and check the float levels. Should be parallel with the carb body float bowl mounting surface. Then again, if it works when you raise it a bit, I would not worry about it, if it runs good at other RPM's...
