I am having Electrical issue with my 1988 Bayliner 1750 2.3 liter OMC Cobra. The problem is: In the 1st 2-3 seconds of turning the ignition switch to the "Start" position, 1 of the 50 amp Main Fuses blows. I have replace all Ignition Silenoids, Ignition Coil, Ignition Switch, Starter, Main Positive & Negative wire from battery. I was unable to have the Alternator tested but it was working fine prior to the fuse blowing. I have performed regular tune-ups and maintenance. There is no visible burns or damage to the wire harness, the fuses under the dash are all good. The boat was running great just before the problem arose. Any help with this problem would be greatly appreciated?
