uthornsfan
- Mar 6, 2011
- 8
I have read through most of the Force Tilt/Trim threads on the forum and searched high and low and hope someone can help me.
I pulled my Pump apart and replaced the 2 orings in the bottom valve body. However before doing that I took the top plate of the valve body off. The one where there are 3 big ball bearings 1 small ball bearing and a couple of springs.
I haved edited this post so hopefully if anyone is searching for the same thing I was they can find this easier...
The Oring Part numbers for the Leak down problem are
tecumseh 631021b briggs & stratton 22-10055 which replaces 398188
http://www.mfgsupply.com/m/c/22-10055.html
Force 125 Valve Body Pump Tilt Trim Pictures Disassembly Assembly tear down break down Pics Picture
