88 Force 50 sacrificial anode?
coachtom2183
Hey guys quick ? I have a 1988 50 force on a 89 17 ft Aluminum Seaark I bought a month ago from a bass fisherman I Use the boat mostly in Salt Water Flats I have puchesed the manual motor runs great especialy after decarb I have replaced fuel pump lower unit oil lubed sparks and impeller I want to make sure I am protecting the motor and boat from saltwater I cant locate the sacrificial anode for motor.Plus any tips for boat itself currently zero rust.I know you guys can come thru for me thanx
WillyBWright
Re: 88 Force 50 sacrificial anode?
Mercury offers a spray-on protectant called Corrosion Guard. Spray the powerhead down with some of that. Otherwise just flush it and keep it hosed off. I don't believe they had anodes on those. If you trailer it, you probably don't need one.
roscoe
You could buy an anode and bolt it onto the anti ventilation plate.
