relics hunter
- Jun 11, 2010
- 118
What's with the water problems, It seems like a outboard water gods have something out for me. My 35 hp had bad water deflectors and then a bad exhaust gasket all the advise I got on that was great and it's running great. The 6hp had been running good for months getting some good fishing in and then the last time out It acted weak on the last short distance to the dock. It wouldn't get up and go, and when I ran it to clean it out after getting home the tell tail seemed weak, and noticeably hot. I ran some vinegar through it and checked for clogged intake. I pulled the foot and looked over the impeller, which is maybe 6 months old. I happened to have another new one and swapped it out. Put the foot back on and ran it, still a weak stream, and hot, and I turned it off when the temps got to high. I pulled the thermostat cover off and cleaned and tested the thermostat. I did find that the previous owner decided to use silicone sealant instead of a gasket, and perhaps there are fragments of sealant deeper in the motor. I cleaned all I could reach and reassembled with a gasket. My understanding is the water comes to the tell tail just after entering the upper motor, and then passes through the thermostat and on around the cylinders and such. Thermostat tested good. So for the water in the tell tail to get quite warm/hot it seems to not be moving along like it needs to. I am getting water and exhaust spitting out the back port. One of the symptoms of the blown exhaust gasket on the 35 was no water with the exhaust. It doesn't look like the 6hp has water deflectors. I did feel a little temp change as the thermostat opens and closes, so I believe it is working. I am thinking I have to tear into it and find some scrap of silicon that a nit wit added to the system.
What do you think?
What do you think?
