88 Johnson SPL - lower unit oil color
savenelroy
Just replaced the lower unit oil on my 1989 Johnson 88 SPL. Is this what used oil should look like? It's my second year owning a boat, and after the first season, it was milky and green. I brought it in and had the seals replaced. I used it all season but don't have anything else to compare this to other than images from a Google search. Everything I'm seeing looks a lot darker than this.
tphoyt
Looks ok
Be sure to replace the nylon washers with new ones.
jerryjerry05
That's NOT right, it shows it has water in it.
Drop the lower unit and then do a pressure test.
Motor just ran just before draining?----Then it looks like air in the oil.-----Tiny bubbles= no troubles !
iggyw1
Ensign
I will be draining mine tomorrow morning, and I am hoping mine is looking that good when it comes out!!!
oldboat1
Moot point, as you will be refilling with clean oil anyway, and maybe doing pressure and vacuum tests as a precaution.
savenelroy
Yes. I ran it for 5 minutes to warm up the oil so it would drain out better. Starting to get cold here on the east coast.
havoc_squad
No need, this is not a motor oil change.
Put a jar to capture it under it with drip pan. Take out the vent and drain plug, go take a short nap or eat and then come back.
I never check/drain the lower unit lube condition afterwards on the same day it is ran. It's a good way to kneejerk worry about a problem that may not exist.
As racer said, the air bubbles/foam can occur. Those bubbles may get mistaken for water intrusion.
The only exception to not checking the same day will be is if there is a suspected/possible water intrusion, suspected loss of lube level, or checking the condition during freezing periods of the year.
