So I bought a boat with an Evinrude 200 xp 1988 model sitting on it. I took her out on her first test run and noticed I couldn't get her over 3200 RPM trimmed out at WOT. The previous owner had replaced the VRO pump with an electric pump without a regulator and left the old VRO pump hooked up in line. (side note I also used 6 gallons of gas in about a mile and a half). She had some gas leaks. I replaced all the fuel lines with new ones and used clamps instead of zip ties to secure them down. I cleaned all the carbs and took off the old VRO pump as it was allowing fuel to dump into the pulse hose which was dumping excess fuel into the crank case. I thought this was the problem but it is not. I did a compression check and although low, the cylinders were all consistent around 70 to 75. I changed the spark plugs but I still can't get her over 3200 RPM's. This is driving me crazy what could it be?
