after reading this site im sure someone can help my motor will idle fine but when you take off it plaines out and runs about 30 sec then boggs choking makes no difference and i already rebuilt the fuel pump and cleaned out carbs only thing after i rebuilt the pump the boat sat for almost two years before i tested please somone help me thank you i forgot to add if you pump the ball it will continue to run on plane like normal till you quit pumping
