'88 Merc 80hp - No Spark
crashed
Hi,<br /><br />As the subject suggests my Merc 80 (1988 3cyl) refuses to start. The engine was running fine, switched it off, tried to restart about 10 mins later and it wont fire...<br /><br />Checked it over (albeit at sea with minimal tools) and there doesnt appear to be any spark.<br /><br />The buzzer on the control box sounds for about 2 seconds when the ignition is switched on and then you can kinda hear it trying to sound as the engine is cranked.<br /><br />I have a wiring diagram and will hopefully check it out this weekend, just wondering if there is any common problems on these engines that cause this, or if there's anything in particular I should be looking at..<br /><br />Thanks
ross_larter
Re: '88 Merc 80hp - No Spark
Hi,<br />Remove and clean your battery terminals (even if they look ok), you need a good connection to spin the starter.<br />Ross.
crashed
Hi Ross,<br /><br />Engine turns over no problem & I am getting fuel, just lacking in the spark dept!
go to outboardparts.com, they have one of the better trouble shooting regimes, and they keep it simple for use with multimeter.
