88 spl overheating alarm going off, motor not hot
srussell28
I have a 87 88spl that this weekend when coming off plan, slowing down to idle what I think is the over heating alarm started going off. Turn the engine off, waited a minute, turn it back on a few minutes later started going off again, if I idle above 1000rpms it would stop going off. Did the same thing got back to the dock, went home put it on the muffs no issues. The motor was not hot at all, the pee-hole had great water coming out. I did notice that there was a buzzing out of the control before the alarm went off. I have a manual, and read other treads about checking this and that, were should I began? Treshdaddy please help. Can someone post a picture of where the tan wires that goto the overheating sensor. Do I have 2 sensors because of the v4? Do I have a engine that also has a alarm for the fuel? I don't have the VRO, I mix the gas with oil 50:1. thanks for the help.
tashasdaddy
Re: 88 spl overheating alarm going off, motor not hot
no fuel alarm, when was the impeller last changed? sounds like it's on it's last leg. not pumping enough water till over 1000 rpms.
srussell28
thanks for the quick responce, I got the motor a bout 1 month ago, the guy told me that the water pump just been replaced. The water was pumping the whole time and was not hot. I will contact him to verifiy this. thanks.
tashasdaddy
you don't know how many times i've heard just replaced. yeah, it may have sat a year without use.
