Re: 88 Yam 70 overheating@ high RPMs
The compression numbers are OK, but a leaking head gasket doesn't always show up on a compression test. Are any of the spark plugs really clean? Have you always had this problem or did it just show up? You might want to verify that the engine is in fact overheating. You can buy a point and shoot infrared thermometer at Radio Shack for about $50 to check the cylinder head temps. If in fact it is overheating you may want check the carbs for too lean a mixture and the maximum ignition timing. When you replaced the impeller, did you check the water pump housing for signs of wear? You may have to go and pull the heads. Buy a manual. Its not hard if the bolts don't snap off (that can be dealt with too). Check for old pieces of impeller in the cooling pasages when the head is off. Make sure you torque the head bolts to manual specs.
