88 Yamaha 90 HP Oil Inj. leaking into cylinders when not running
herndo1
I'm' finding Oil that has leaked onto the ground below lower unit, that appears to have come from exhaust port around prop, which there is oil dripping from the skeg on the lower unit. I was told that the internal check valve within my oil pump is letting oil pass thru into my cylinders and then out the exhaust port. When I first start the engine after sitting for several days there is massive smoke but finally clears and everything seems OK. I had some inline Yamaha check valves installed in the oil injection lines that run to the carbs. Thought everything was OK but found more oil on the ground today.
Please Help
Thanks in advance
Adrien
rodbolt
Re: 88 Yamaha 90 HP Oil Inj. leaking into cylinders when not running
could be a check valve if you have the old style kein pump with the checkvalves in the pump, could be the oil pump shaft seal leaking. if its the check valve either buy the mikuni pump kit or try to splice in the later style inline check valves, make sure you do all 3 lines. I would prefer you replaced the pump.but it may be as simple as the oil seal.
herndo1
[quote time1151632410= userrodbolt= uid32169= fid30= tid= rid1= could be a check valve if you have the old style kein pump with the checkvalves in the pump, could be the oil pump shaft seal leaking. if its the check valve either buy the mikuni pump kit or try to splice in the later style inline check valves, make sure you do all 3 lines. I would prefer you replaced the pumpbut. it may be as simple as the oil seal.
[/quote]
Im
I'm pretty sure I have the old style pump. I did install the later style inline check valves and installed them on all three lines. If it's the oil seal is there any way for this leaking oil to make cylinders' way into the cyliners?
herndo1
Thanks for the reply
herndo1
herndo1
Im
I'm pretty sure I have the old style pump. I did inline the later style inline check valves installed on all three lines. If it's the oil seal is there any way for this leaking oil to make cylinders' way into the cyliners?
herndo1
herndo1
[/quote]
rodbolt
yep, it will normally flood the bottom cyl. aint but two ways oil can enter the engine, either through the lines into the reed cage area or past the drive shaft seal into the lower cylinders crankcase area.
