ledgefinder
Ensign
- May 2, 2002
- 916
Here's a puzzler (at least to me). I just got a 1988 Johnson 88 SPL. On a test run, the starboard cylinder head is too cold (almost no heat at all after 5 minutes slow, just a bit of heat after 2 minutes full throttle). The port head is just about right - after 5 seconds, you've gotta pull your hand off it. I did pull the starboard head to do a thread insert, but am sure I got the gasket on there with slots in the lower starboard corner, as directed in my manual & on the gasket, and by common sense (looking at the flow layout of the head & cylinder). Any ideas what's going on here? Seems like thermostat is working, or else the port head wouldn't be correct temperature.
