16ftsunbird
- Mar 19, 2015
- 59
I have a 1989 15hp i started it up today a couple of times because it has'nt been run in awhile i noticed when i went to shut it off the kill switch would'nt do ti so i used the switch on the side however i did push the kill switch very hard so i went to start it again and it would'nt start i have no fire on i think it would be the # 1 coil or top cyl so i change the plugs around to elimate a plug both are good so then i switch coils around and what i think is # 1 coil after switching around it fires and no fire from the other coil after changing around so i guess the question i need to ask does the kill switch kill both cyl's or does it just kill what i'm calling the # 1 which is the upper cyl if so how can i test the kill switch to see if it's stuck or do i have another problem
