Living4Fishing
- May 25, 2006
- 19
I'm beat on this one, I just got the motor running great. I took it out for a day on the lake, ran fine for about an hour. I noticed the tell tale stream getting weak, as I went to shut it off the motor the stream quit, I trolled back in.
When I pulled the impellor it looked ok, I put a new one in. No water in tell tale when I started it. I pulled the t-stat when I started it no water, not a drop, came out of the t-stat hole. I saw now debris in the tubes from the water pump. There was nothing to speak of (debris) in the cylinder head cooling area.
When I replaced the impellor I could see into the water opening in the foot of the motor. I do not think the water pump was at fault nor the t-stat.
What should I check now? Thanks so much for the help, I want to fish a little this fall.
