I have a 1989 OMC I/O 3.O in my Bayliner. Have never had any shifting problems until this year. The shifter was very stiff this season on its first run when i was trying to shift between gears. More importantly anytime the shifter was in neutral, the esa would engage the entire time. This meant I had no neutral the entire day which meant no restarts. The boat shifted fine into forward and reverse but if it was put into neutral the esa engaged and would not disengage unless put into a gear. The esa seemed to be working fine when shifting, but just wouldn't disengage when in neutral. The boat would just idle down to almost a stall and stumble. Also when in neutral, because of the esa, I could not rev up the engine to keep it running.
I've found ESA replacements on iboats, but can't find a part number from them or dougrussell. It appears as though they no longer have the exploded parts views for parts numbers. Any idea on the part number?
Is there just a cleaning or adjustment that needs to be made?
Any help would be appreciated. I'd like to fix it asap. Thanks!
