I checked my carbs for the low speed idle adj. On top of the carb there is a brass tube looking thing with a screw slot in the end. It is on an angle facing the starbord side is this the low speed idle adj.? Or is it inside the air intake chamber? I mean do you need to take the front cover of the air intake off to access the idle adjustments? With the cover off you can see what looks like an adjustment, what is that for?<br /><br />Gill009, <br />You said you have a Haynes manual, I do not want any copies as I know they are copywrited, but If its not too much trouble just some type of order of things to check.<br /><br />This is what I have:<br />*Both carbs perfectly in sync opening the same.<br />*In netural, carb. roller slightly touched cam at the mark.<br /><br />This is what I need:<br />*Order of things to check.<br />*What is the distance between top swivals controling the timming?<br />*Low speed timming, if it matters I mean perhaps with all other things adj. the low speed timming may just be set.<br />*What is the low speed idle rpm?<br /><br />I think this is enough at this time.<br /><br />I plan to check wot timming as Joe Reeves has mentioned before I run it again and adjust 4 degrees less than what it calls for.<br /><br />Thanks in advance,<br />Beck<br />
<br />I plan to order the oem manual if I keep this engine, I hope to upgrade in boats and keep this engine but would like to wind up with a 70-75 eventually.
