89 5.7 Mercruiser, Vortec Heads
NHGuy
If I want to do Vortec heads on my 89, 260 HP, 5.7 small block GM with center bolt valve covers what else do I need to make it all happen... and what else SHOULD I do to make it right?
Should I change the cam, do I have to? Do I have to do the intake manifold? Can my Rochester 4 bbl handle the increased air flow?
And can my through the prop exhaust handle the outflow?
I am aware that alpha 1 drives should not be hammered from a dead stop with this kind of power and I will keep the good lube in it.
This is a back burner plan, I'm just dreaming at this point.
Re: 89 5.7 Mercruiser, Vortec Heads
Ayuh,... The matching Intake Manifold....
All your questions have been answered here before,... Repeatedly....
Do a Search....
John_S
No, the flat or roller hyd marine cam is fine.
Yes.
Yes, and then some. Might have some tuning to optomize.
Yes
