tfbrown1270
- Sep 5, 2003
- 202
Hi all....Just so you know...I have replaced the two exhaust manifold gaskets, replaced the head gasket, replaced the fuel pump gasket, cleaned the carbs with seafoam, run fresh gas with seafoam in it (many cans worth) to correct a constant problem with rough idle and stalling......the compression is 135/135/130 top to bottom...I have a problem starting the thing and getting it running so I can move away from the dock at reasonable rpms........I have to shift arounf 1000 rpm and if the I let it get under that it "burps" and quits
........what next...<br />Thanks Tim
