DamianJP
- Mar 25, 2008
- 612
Hello
Iv'e been working on a 89 Blackmax 150 XR-4 and had a couple questions.
Just did the Poppit complete, Water pump complete, Fuel pump, T-stats and Warning horn.
Used to get 0-1 Idle
3-4 50%
7 WOT PSI
Now I get 1-2 Idle
7-8 50%
22 WOT PSI
Used to go from 1/2 to 3/4 on temp gauge and always stay hot until shutdown. Be alittle better at WOT but never to move temp down.
Now It's same, idle but alittle worse. Goes alittle higher past 3/4 mark, but anything 7-8 to 22 WOT it seems like the heat is under control and temp never breaks 1/4 and change
I replaced everything in the poppit and put back the way it was, and now get a small leak out the vent hole. Anyone know what it might be. Also what are the torque settings for the screws? I think the leak is contributing to my Idle over heat be worse. Lemme know what you think.
Warning horn sounds sometimes for key turn sometimes not. Also I get the Oil beep-beep-beep and it will match the engine RPM.// Fast RPM Fast beep// Slow RPM slow beep// Seems like it is the plastic gear for oil pump about to go or it is slipping due to me letting the motor overheat before I got the water pump. Either way Im nervous and want to look into Pre Mixing until mabey I can rebuild pump. Is a oil pump cap all I need or are there other parts? Whats the deal?
Thanks,
Damian
3-4 50%
7 WOT PSI
Now I get 1-2 Idle
7-8 50%
22 WOT PSI
Thanks,
Damian
