89 Doral Tara 240 Fuse Panel
nrostrander
Does anyone have a wring schematic or know where a schematic is for a 1989 Doral Tara 240? I am trying to figure out what the 2A fuse was for, as its wires are not connected.
Ayuh,..... Welcome Aboard,..... Hull wirin' diagrams are rarer than hen's teeth,....
Trial, 'n error with a test light or meter is how I figure out what's what,.....
2 amp is probably a radio, or other low power use appliance,....
Silvertip
Many boats have accessory switches and/or breakers, some of which may not be used depending on the accessories installed when the boat was built. If the hot lead from that fuse is terminated with a butt splice or some other type of crimp connector, it likely never was used.
