89 evenrude 15 shifter lever and yoke assy and replacement of seals
jwoody
I am replacing a cracked bearing housing and in the process I decided to replace the seals on the end of the bearing housing, so I have two questions. First how do I get the seals out? Second, In this process I managed to take the proppeler shaft out and I can't get the CRADLE, clutch dog back into the SHIFTER LEVER & YOKE ASSY. Is there a solution to both questions?
kbait
Google 'leeroy's ramblings' and navigate to the 9.9/15 section and look around.. I think he details the procedure there.
Good luck!
