I bought an 89' Evinrude 140 a few years back and need to do some rebuilding over the next few weeks. I'll list symptoms and history, any suggestions or/and recommendations would be greatly appreciated. Thank you
89' Evinrude 140 VRO
After the first season it ran rough at idle or one click in Fwd or Rev and occasionally sneezed until it died, I assumed the carbs needed to be cleaned.
I figured I'd do it over the winter though since it didn't happen that often and I could just restart it with ease and be fine. It got worse over time.
Last June the warning horn went off and the engine started bogging, I shut it down and when I got back to shore tested the horn and was told it was running oil deficient. I disconnected the VRO, installed a new fuel pump that ran just mixed gas and everything was fine. It ran with no issues until mid August, (no issues outside of the progressively worsening idle) again I was just hoping it would get me through the beginning of September. I started noticing water draining into the boat from the engine when it was tilted up. I lowered the engine and everything was fine, only a problem when it was tilted up. It got harder and harder to start when cold, no issues (outside of idle) once warm. Finally it died one day and really didn't run under load. I got it going and found that only 2 of the 4 cylinders were running (while running pulled plug covers and no change one side / totally died when pulled on other side.) I AM getting spark though and the plugs remained pretty dry on the dead side and on the muffs it runs fine. I'm going to rebuild carbs next week and would really like to try and take care of everything in one weekend as oppose to dragging a system by system rebuild out for the next few months.
I'm anxious to just order parts and get everything done, but also want to retain some weight in the old wallet so I'm looking for the best balance. Any help will be greatly appreciated. Thank you
