OK, just received the replacement gaskets tonight and ready to reassemble tomorrow. The new gaskets are definitely more modern gaskets then what came off. Unfortunately no adhesive strips on any of them. So back to gasket adhesive, brush on Permatex High Tack should be OK right? And should I put it on only 1 side or both. There is just a lot of play in these manifolds and gaskets and I don't want them to slip. Also, I have normal aluminum anti seize, and that is all that I can find locally, that should be ok correct? I went with zinc plated bolts because of the increased galvanic corrosion with stainless, and don't want to take a chance on a grade 8 breaking in the future and having to try to drill it out.
