89 force 50 hp wastes and squirts fuel
Eddie Rivera
look at the picture with the red mark - am i missing a cap??
89 Force 50 HP wastes too much fuel and I increase the throttle it squirts fuel from end at bottom- where the carb meets the block. Also at high speeds it squirts from the small plugs and leaks out a lot from the lower bowl and it bogs out at high revolutions.
I have the new gasket kit with 3 gaskets. one for the bowl and two little ones. I have the gasket for the area where the carb meets the block also I got a new floater. I've never worked carbs and I'm intimidated.
Please advise! On procedures or what to watch out for or anything else. Thank you
jerryjerry05
Re: 89 force 50 hp wastes and squirts fuel
That hole is for overflow.
No fuel from anyplace other than the tiny hole.
Maybe a bit from the front of the carb(tiny bit).
Small plugs? You mean the top of the carb? That's a definate NO!!!leak zone.
Will post a couple of pics tomorrow of the carb setup right.
