89 Force 85hp stripped hex on lower unit drain plug set screw
Quastello
just looking for some help getting my set screw out, ive tried tapping extractor in there and turning out didn't want to drill if I didn't have to but that didnt work to well I kinda got chicken that id wreck the threads any tips or help would be appreciated as snow is coming thanks jeff
Post a pic for us to see what your working with
Quastello
its the small lower unit drain plug set screw sorry its dark will be hard to get good pic
I would be tempted to hammer in a metric Allen key or torx bit to get some bite
Quastello
ya I tried an easy out but chickened out didn't want to wreck the treads I'm thinkn a left handed drill bit or take it to shop which I hate to do
jerryjerry05
I use a small torch if the screw isn't coming out.
​There are no seals or anything that can be hurt from the heat.
The screw can be drilled out and an "easy out" used to remove.
There is a "boss" made into the area around the hole and if needed you can tap the hole to a bigger size.
​I've never been able to make the screw seal no matter what I used.
Pipe tape, pipe goop, nothing seems to work.
​It always seems to weep a small amount.
​I just change/ check the oil a lot as the drives are getting scarce.
​I do have a spare but would hate to use it.
Remember it's soft aluminum.
​Driving a Torx bit in? Be careful.
Quastello
I got it guys beat easy out in and applied some heat with small torch and had tap handle on came out no prob thanks for the help guys
Scaaty
My 125 been froze for ten years. No big deal as to drain oil, just pull the prop, etc. Take the bottom 2 carrier bolts out. Motor down far as ya can and 90% oil will drain out.
