89 Force125 butterflies not fully open at WOT
Glenn Iverson
Been trying to solve this for awhile now. I have the throttle arm scribe mark lined up with the cam so that it intersects. Throttle stop screw just touches engine block. Nice 700 rpm idle in gear & even acceleration without bogging. Problem is with throttle fully open the carb butterflies are 3/4 to 4/5 open at wot. I get 45 -4700 rpm & 37mph with my 89 Arriva 20 ft. boat with a 17 pitch prop. Before I would extend the throttle linkage arm to get the butterflies to open & could get 5000 rpm & 40mph but would suffer from flat spots during acceleration & loading up the carbs with gas. It runs well now just not achieving full throttle. I have a timing light & remote starter switch. I will check the timing this weekend. Will static time to 28% WOT if not already there. If I find the timing happens is retarded will advancing to 28% WOT help the butterflies to open atl the way? I suspect the previous owner may have played with it.
Glenn Iverson
I might add when I disconnect the throttle & shifter cables & move the throttle tower by hand all the way to Wot the butterflies do open all the way flat. It is as if the shifter is limiting my throttle.
jerryjerry05
If it can't be adjusted at the linkage??? then the shifter could solve the problem.
​They come with 2-3 extra holes and maybe changing the hole might give you the extra throw??
Glenn Iverson
I was thinking the same thing. I have one of those US marine flush mount control boxes. If I can figure out how to get it out of the side panel I will try that.
pnwboat
Depending on which control you have, the black plastic cover is split in two. Each piece just slides off exposing the mounting bolts and mechanism.
