89 johnson 150 idle problem
mark2464
Motor does not idle well when trim is all the way down,trim it up a little and it
idles and runs good. Is it not getting enough gas or is it flooding when trimmed all the way down?
jonesg
Re: 89 johnson 150 idle problem
It could be a float issue in the carbs.
bump.. back to the top again.
mark2464
Thanks for the info I will check that out.There is two more things I have noticed,1) It smokes real bad when I start it with trim all the way down.2)It is slow to plane. Could these also be carb problems. All info is greatly appreciated.
jonesg
slow to plane?
smokey...
what are the complete symptoms?
It could be an air leak in a fuel line, that can cause a VRO pump to cycle quicker and dump extra oil into the intake.
You might do better by baselining the engine .
compression test it.
spark gap test 7/16th inch gap on the tester.
emdsapmgr
A couple of things could be an issue. Engines idle slowest when deepest in the water-due to the backpressure in the water. If you tilt it up, there is less backpressure and the engine rpms will slightly pickup. Possible you need to sync and link the engine. If the carbs weep/leak any fuel into the airbox, the excess will accumulate at the bottom. When the engine is trimmed down, it will get sucked through the airbox drain hose into the crankcase #6 cylinder. Excess fuel can cause a temporary poor idle (smoking) till it consumes this fuel. Once consumed, it should idle normally. Remove the airbox cover and idle the engine in various tilt positions and see if you get any fuel dripping into the airbox. Poor idling can be caused by restrictions in the idle circuits in the carbs. Dried residual fuel can be a real problem in any fuel passages in a carbed engine. An aerosol carb spray is good to clean out these passages, and the rest of the carb passages as well.
