ASwan73
- Jul 15, 2015
- 11
I have a 1989 Johnson J70TLCEM 70 hp that idles at around 1000-1100 on muffs but put it in the water and it drops to 750-800. How do I get this so it idles at 1000-1200 rpms in the water? It will stall out of the rpms get too low. Replaced all filters and lines yesterday and check spark air gap is good and carbs are good. Do I adjust the idle screw while on the water or can I do it on muffs and take it up to about 1400 on muffs and it go down to the desired area while in the water since the water adds back pressure to the exhaust system.
