jakers4777
- Jan 11, 2003
- 12
89 Johnson thermostat
Thanks to the tips and info I've received here on the forum I have managed to rebuild my carbs, put on all new fuel lines, uninstall the VRO and install a standard fuel ****.<br /> Got one question. I'm not satisfied with the amount of water coming out of the pisser. I put in a water pump kit last year and the flow looked good. I want to back flush and check the thermostat but: the Johnson service manual I have does not show the location of the stat. I'm assuming(and hoping) that it is behind the large nut just above the upper spark plug, right?<br /> Also, what are the opening and closing temps supposed to be? Check it like an auto stat with a thermometer and hot water?
