89 johnson waterpump
cmc636
I'm not sure if my message went through.<br /><br />There is more water coming out my lower unit than out the spigit on the engine compartment what could cause this, I just replaced the impellar.
Hooty
Re: 89 johnson waterpump
That "spigit " is just a tattletale to let you know the water pump is working and water is circulating.<br /><br />c/6<br /><br />Hooty
ob
CMC636,What part of the lower unit are you speaking of that there is more water coming from?Is it leaking at the horizontal joint more so than before you changed the pump?Need more info on your specific question.
