89 mariner 150hp tach help
river rat1
can I wire my tach up straight from the battery or can I use a toggle switch or do I have to use it straight from the control box just the power im talking about thanks for any help
Chris1956
If you wire the tach from the battery, it will be using current all the time, which will run the battery down. A switch is better. The best is powering it off the ign switch accessory post.
