Hi all. Thanks in advance for any and all inputs.. your help will be most appreciated.
What I have in an 89 marlin 21' w/ a OMC 350 Cobra. Last outing we were cruising along about 30 mph, decided to go faster and 10 seconds in to wide open we stopped moving.. by that I mean it was if I let off the gas all of a sudden, but I didn't. Let off the gas and stopped. Tried to engage drive, heard the quick grind/click, and gave it some gas.. the prop didn't turn, and heard kind of a high pitch whine. Same for reverse.
Out of the water, not running, when I engage the drive the prop used to lock to where it would not turn with ease. Now you can freely spin it and hear/feel a bumpy resistance. When we started it in the driveway, you can clearly hear the drive engaging, and the prop starts to turn, but only barely. I could have probably grabbed it and stopped it..
Some people insist its a cable issue, but I'm not so sure. For the last few outings, I noticed that when engaging drive, if I don't give it some gas and try to stay at idle speed and just put-put along, I would hear a faint grind sound, and it would slip in and out of gear. I would have to push the throttle down a touch more and move along a skosh faster than idle.
I know the thing also probably has other issues with either the carb, or maybe fuel filter. Stabbing the gas from a stop or crawl always results in sputtering and stuff.. have to get going smoothly at a slower rate.
So anyway, thats what I'm looking at right now. I feel it's likely I have something bag going on, but wanted to see what you all might think.
Thanks again for any input!
CB
CB
