I have just started to "play " with inboards, getting a great deal on a 89 MC prostar. I have one problem. I am overheating at idle, but when I start to move at 10MPH or faster, I then get back into the normal range. I am told that it is my impeller, and I was told to change it out every year as yearly maintanence. But How does it work? I understand that when I am underway, I am pushing water through the impeller and thus cooling the boat. But why will a bad impeller not work at idle? Does it work by vacuum? Why does a good impeller work properly at idle? Also what other spots should <br />I check while I have the impeller off??
