plugs fire on all 6 cyl. fuel pump good, hoses and connections good, oil rod adjustment good. enrichment valve good, compression good,temp sensor good, fuel clean and good filter. bulb good. not running hot either. Temp @ 148 <br /> problem occured once before, it wouldnt get over 2000 rpms. but i held the throttle down and it just cleared up on its own. Ran fine for 3 -4 months with no problem. then without warning its back. was running great around 4500 rpms and the bottom just fell out. nothing more than 2000 rpms. <br />I tried to test stator but the color codes in the wiring schematic in the seloc manual show different colors than mine when I guessed at it I got around 28vac and regardless of what wires I tested together, I never got any higher reading. Any suggestions?
<br />any help or advice appreciated. thanks Randyc
