vintage_snowmobiler
- Jul 3, 2012
- 5
I've done a little looking and didn't find what i was looking for, so my apologies if i missed something and make a duplicate. I have an 89 mercruiser 3.0 with the DDIS ignition. For the past several years i've had an issue with hesitation during a hole shot. Even if cruising and rapidly increase the throttle the engine hesitates. I've rebuilt the carb, bought a rebuilt carb, replaced plugs and wires numerous times, changed the pickup coil, set timing, everything, and the issue has stayed the same, did not get better or worse. I had the troubleshooting guide to the DDIS system and all checks are within specs. Finally i read that there are many issues with the system and parts are expensive, if even available and that it's better to convert to the EST ignition system. I have done that and have most installed. My only question is what side of the switch interrupt switch to i connect to. Since i'm not 100% sure how it works or what it does, i don't really know what side of the switch to connect it to. Thanks for any help that can be given.
