I have a '89 Merc 4.3 with the 3304-9565 Rochester Carb on it. The boat starts cold great and idles perfectly. Once warmed up if I slowly increase throttle it starts to bog and will die around 10-20% throttle. If I push it past 20% up to like 60% it will catch and rev up. It runs at WOT perfectly fine. Another possibly related issue to this is when the motor is hot it does not want to start right up, I have to give it a pump or two and as long as I dont flood it then it will stumble for a second then start up and idle. If I flood it then it absolutely will not start unless I let it air out or spray starter fluid. Does this just sound like I need a good carb cleaning? Clogged jet maybe? I have a rebuild kit on the way now for it but I wanted to pick the brains of the experts before I dug into this. I have extensive experience with motorcycle carbs but this is my first automotive style carb.
Also, side question, do I need to remove the carb fully to refresh it or can everything be done with it installed on the intake?
