NeedingThisThingToRun
- Jun 27, 2008
- 7
I have a 89 model 85hp Cabrea made by suzuki model number EL85P (same thing as the DT85). I recently bought the motor after it had been setting for nearly 3 years. Ran a compression check and all three cylinders seem to be decent. Trouble is the motor won't run wide open, not even close at about 1/4 throttle it seems to run out of gas. I've been through the carbs, went through the fuel pump, checked for vacuum leaks. I bypassed the onboard fuel tank and tried running it from a fuel tank I use on my other boats to ensure its not a tank or fitting problem. Same story. I can only find 1 adjustment screw on each carb and that's the rich-lean adjustment screw. With all carbs running as rich as possible and the choke butterflies closed it runs better which makes me think I've got an air leak somewhere. I've checked all gaskets on carbs and vacuum hoses. Can someone tell me what I'm missing here. I've got alot of money in this setup and hate to dump a bunch more at the dealer. Is there another adjustment screw somewhere on these carbs to get more fuel? Thanks for any help
