89 wellcraft fuses
canoboy1983
i have an 89 wellcraft and was wondering what size fuses would be needed for the bilge pump, temp gauge, and the horn?
seabob4
Re: 89 wellcraft fuses
Bilge Pump, 7.5A
Horn, 5A
Temp gauge is protected through the engine fusing...
canoboy1983
is there a fuse between the battery and the fuse panel? there is no power to the fuse panel. my radio is connected directly to the battery and now that is not working either. my battery is fully charged
seabob4
Look in the bilge area. Coming off the battery, there should be about an 8GA wire that feeds a 40A breaker. From that breaker, another 8GA will run forward and feed your fuse panel under the helm. Then all the individual circuits are protected by the fuses in that panel...
canoboy1983
no there was no fuse in between the battery and the fuse panel, it was just that the previous owner didnt know what they were doing when they tried to rewire the panel i guess. The panel and connectors were pretty corroded also. Changed everything and all is working. Thanks for the help.
seabob4
