A friend of mine has a '89 225 yamaha that stalled while at sea although it would it would run on trailer.I informed him I had seen this before and that it usually meant that it dropped a cylinder.After convincing him that the easiest way to tell is to do a compression check and he agreed and the#1 was 100lbs,#2 was132 and the rest were close to 115lbs.I did check this with engine cold and dry.I told him he basically needed a rebuild.Since then his usual mechanic did another comp. test with engine warm(1/2hr running)and lubricated cylinders before checking compression and said engine is fine.The only reason I got involved was that I was planning on doing some 40 mile runs offshore with him. I told him I would buy a new engine b/c his was shot(he could not afford one).He now thinks that I just wanted a share in his boat and thinks I was trying to rip him off.Did I diagnose it right?Won't the lubricant falsely raise comp.,plus checking it warm?How good will the engine run or will it run at all with that much of a variance in compression? Much Thanks Michael
