Changed impeller, tested and no tell tale. Have cleaned pee holes. Pulled thermostat and it was pretty corroded but didnt look stuck fully closed. With cylinder cover off, cleaned as far into water ports as i could and didn't seem to find any obstruction. I have ordered a new thermostat, however, I'd like to start it without it to see if it will pee. Will this harm the engine if only run for a short time? Also, every forum and dealer I ask says motor should pee. If it won't pee without thermostat, I have decided it isn't meant to or there must be an obstruction inside engine block. I sprayed water up pump line with cylinder cover off and the water is making it into engine. Also, when testing new impeller, I had plenty of water discharge at prop. I even sprayed water into engine holes in cylinder cavity and nothing exits pee holes. There is a tunnel that runs water down lower unit and out at foot though. At my wits end here. Again, is it possible that this thing does not pee or will it harm it to start it without thermostat to see if that is the problem? I cannot find a single diagram that shows the water path throughout engine....which would help tremendously.
One more thought. As stated above, there is a passage that runs water to foot. Is it possible, that pee hole lines are part of this passageway and damaged and simply getting bypassed? Sorry for the long post.
