So I unplugged both the on/off switch and the kill switch on the throttle at the switch box, and still no spark. I downloaded the Serv Man and it tells me to check the resistance at stator. Black white tested Good. Black yellow was infinite. Service manual doesn't say what that means or what to do next. What do I do next? Does this mean that the stator is bad or that something else is at fault? Thanks.!!!! EDIT: If i change the Ohmeter to KOhms, it reads 2.0 The Serv Manual says it should be 6.5-8.5 Rx100
