Re: 8hp Yamaha 2 stroke
i have motors that use 10:1, 16:1, 24:1 and 50:1......and i do have an evinrude that was spec'd at 100:1, but was mixed at 50:1 from new, its an 1984 ( i think).....that motor still has the original plugs. im no expert but the mix ratio is based on the type of bearings/materials used in the rotating assembly. ie....my 57 johnson has bushings and needs lots of oil....16:1, newer motors have bearings which require less, but more doesnt hurt. if i were you, id mix at 75:1 at the very least. and run some 50:1 mix before the motor gets stored for the off season.
