9.2 questions
crybrynt1975
Hey guys, thanks for the help so far i took my 9.2 out for a test run this weekend started first pull everytime and it ran good but i have a few questions please......
It pushed my 14 ft v with 3 people at 5.8 mph which i thought was slow my 7.5 pushes the same at 7mph....
the tiller at one point must have skipped or reinstalled because nothing lines up for start, shift, etc not a big deal but i was wondering if its out of position and thats why i didnt get the mph. Heres a pic of the cam when the throttle is wide open. Also i was thinking maybe because its a 2 blade prop, which is well used......... Looks like i have a oil leak i will need to address dont know if its a gasket just needing to swell from sitting for a few years or????
any help or advice would be greatly appreciated
Corey
2012-10-28_17-16-03_873.jpg2012-10-28_17-16-29_376.jpg2012-10-28_17-16-21_101.jpg2012-10-28_17-16-58_741.jpg
jerryjerry05
Re: 9.2 questions
If the compression is good???
Then start with RPM's
You have any way to check them?
It's possible the prop is the wrong one.
The oil, could be the gas is leaking out of the carb or a weak hose???
