9.5 Evinrude Fastwin
brcptrsn
I just got a 9.5 Evinrude model 9222M. It is a 1972 motor. I don't know any of the history of the motor but it looks good.<br />I am trying to get it running. But I don't have a gas tank. Does this model need just a one line tank?<br />The engine turns over alright but when I turn it over with the plugs out I have gotten some water to come out. Any sugestions?
CATransplant
Re: 9.5 Evinrude Fastwin
Is the water coming out of the spark plug holes? If so, you'll have to pull the head and replace the head gasket, at a minimum.<br /><br />As for the tank, yes, a single hose tank is the right one, with normal OMC fittings.
brcptrsn
I have not checked compression with a gauge but it seems good based on pulling with the plugs in. Would I get this with a bad gasket? <br />Pulling the head and maybe more is something I would like to avoid if I can. If not I need to get to work so I can enjoy it.<br />Thanks for sharing your expertise.<br />A site like this is a great learning experience.
wayne h
Master Chief Petty Officer
get a tank and hose and see if she will run. it sounds weird that u are getting water out of the plug holes already without running the motor. are u sure its water ? was the motor sitting outside ? walmart sells the hose and fuel tank pretty cheap might wanna check them out.
brcptrsn
I think the head gasket may have been right. It was much less work to pull the head than I anticipated. First time I have worked on an outboard.<br />Compression was 45 and 50 psi. I don't know what it is supposed to be but my guess is much higher.<br />The moisture got in the cylinders from sitting on its side I am guessing. Most of it resulted when I had the engine laying on it's back with the plugs out. I would pull the starter cord and after a few tries I would find water dripping out.<br />Pistons look good but have carbon deposits.<br />Ill replace the head gasket and get a tank and hose. If I am not in business, I'll be back posting.<br /><br />Thanks for your advice. It makes this project much easier.
