let me give you a little bit of background first.
we bought this motor used, for like 200 usd, water pump was shot, so we replaced that, but it turned out that the thermostat was shot as well.
we went to take the thermostat cap off, and it was stuck in there, so we ended up replacing the cylinder cover and getting a new cap and thermostat.
this is where we basically are, the head gasket is in there, and we used a silicone sealant for the thermostat cover, the problem is, no matter how much we yank that pullstart, it just wont kick, every 10 or 20 pulls we get a single cylinder fire, enough to make a couple bubbles out the back.
spark plugs are screwed in snug, but not too tight, and were gapped by the mechanic, motor ran fine before this little "overhaul."
if you could help with this, it would save me 200-300 dollars at the shop.
thanks
jgweb2000
thanks
jgweb2000
